Hi All. SteveU. was wrong and would like to correct himself.
Since I "retired" 20 months ago I haven't been keeping up with the current diesel cat devolopemnts.
Lowgear/Casey, if I may, the reason for Jens's original activated charcoal question was to reduce the diesel smell in his close quarters situation. Other members have the same problem. Your solution of changing the fuel type is certianly the most elegantly simple answer to this problem.
However for those times when nessesity says they must use Dinodiesel I think someone it going to have to try diferent activted charcoal schemes. WE wont really know untill it is tried in diferent ways. This will probably be the next easiest solution to the smell problem.
Now here is where I was wrong about the current diesel catalytic converter situation:
1) Sulpher is Not a cat contaminent. The high fuel sulpher ran through a cat was resulting in very high levels of poduced sulphuric acid out the exhaust stream. Bad for plants. Very bad for people. Even bad for structures.
Thank you Chris for challenging to get the right info.
2) The U.S. EPA has a diesel engine retrofit program they are slowly putting into place. This is in addition to manditory new engine requirements.
In response some of the catalytic suppliers are now offering dumb (nonelectronically controlled systems) retrofit diesel catalitytic converters. So indeed it may be as simple as: select and bolt on.
Here are the references:
http://en.wikipedia.org/wiki/catlytic-converterVery good nontechnical explaintion of why, what and who of cats. 20% diesel info --all good info.
auto.howstuffworks.com/catalytic_converter.htm
Too simplifed but has an interesting diesel vidio.
www.easterncatalytic.com/products/diesel.phpThey list a 1.5 " inlet/outlet universal diesel cat.
www.discountconverter.com/diesel/index.cfmLists universal 2.00" & 2.25" ID universal diesel cats for $257.08 & $111.14 USD
Any of these cat should be sized OK for a large Lister/oid twin like Jens"s.
Probably too big for any of ths singles below a 16/1. And my chainsized cat idea at only a 1/2" (13mm) flow capacity would be too resrictve for even a 6/1 single. Maybe later as these suppliers work their way down in engine sizes.
Three ideas in three diferent price ranges to solve a dinodiesel exhaust stink problem.
I am now back to working on my wood makes electricy project.
Thanks for your patience
SteveU.
