spencer:
if i follow you correctly
the second charger pulls 2500 watts from the mains at .79pf ?
if this is the case then your 2.5kva SOM can't get you there without overheating/overloading it
because it has to provide not only the 2500watts as delivered from the mains, but also the reactive power
as well,, which might be as much as another 500, 1000 or whatever watts.
i would have to look up the formula but suffice it to say you have power factor issues that are keeping you from carrying
those chargers at near the charge rate you are looking for.
will the chargers work and deliver maybe 30amps?, 20?, 10? without such a large drop in line voltage?
