Mecc Alte is a major brand that builds world class generator heads. I believe they are #1.
http://www.powertechengines.com/Gens.htmlGeTec also sells some. I am not sure of the brand, but the specs are quite good. They may in fact be Mecc Alte gen heads (just a guess). Or, maybe they make them "in house".
http://www.getec.com/synchron.htmThe ST heads have some major design flaws. I know they are popular, that does not mean they produce quality power. Far from it. In fact, My 15KW ST will only power sensitive equipment in my house when the central AC is on "full blast" (drawing 10,000 watts). Otherwise, the sine wave is quite distorted and nothing works right. Including my microwave, both my big screens, both computers and all 6 UPS's. In fact, even the lights flicker like crazy, driving me crazy. There is no way I could live with this.
By the way, it is not unusual for ST heads to provide better quality power when driving large motors. In particular, induction motors.
One big problem with Listeroid power is that the power pulses cause light flicker, due to the acceleration of the gen head during the power stroke. One makes the assumption that the heavy flywheels are enough to provide smooth output, but at the super low RPM's the Listeroids turn, there really is little inertia in that heavy system. I have a 70 pound flywheel (turning 1800RPM) on my gen head and this helps a tiny bit. The belt squeaks on the power strokes, even under no load conditions. HMMMM.
So, in fact the proper setup would be a very heavy engine flywheel setup (double?), a very heavy gen head flywheel setup and a modern gen head capable of low distortion power.
