Hi All,
I've followed the discussion here regarding the "bounce" and looked at all else I can find (G.B.'s CD, etc.).
I need to be able to run this 6/1-ST5 rig on a slab (attached) garage floor.
Assuming a reasonably well behaved and "balanced" engine, the "frame" is next.
The "simple" (factory recomended) dedicated concrete machine base is, for me, not an option.
I do think weight (lots of it), and stiffness are the most important elements for a "frame".
Then, there is the "isolation" issue.
I was thinking...
What if one used structural (A-500) rectangular TUBE for the "rails" on the mount.
6"x4"x.250" and 8"x4"x.250" are fairly common and available.
I know this stuff "rings" like a bell......but what if one FILLED the tubes with something?
I have considered concrete...Heavy, non-removable, not "elastic". I think this is the stiffest, and heaviest case.
Or.....
What if the tubes were filled with something heavy, and loose...and removable.
Like maybe gravel, or sand, or a mix...(Not as heavy, but CHEAP).
Or.....
Like maybe "Steel Shot" (HEAVY but more expensive).
I am wondering if a heavy, loose fill in the "tubes" might "confuse" and "deaden" the hard dynamic and harmonic pulses.
(Like during an earthquake when the "soil" kind of turns to "pudding")
I'm thinking of the opposite of a "dead blow" hammer.
Of course, this will be set on some sort of rubber "isolation" pad(s).
Another thing I thought about is if it might be better to make the "frame" a fiew inches longer, so the engine is out "on the bridge" instead of beating right on top of the pads on one end. (This, I know requires a STIFFER frame, but spreads the load).
Kevin
