Hi all,
As a former HSDE Brat, factory trained... then engineer, I'll give you what you need to know. The fuel return pipe is a necessity as it handles all fuel bypassing the needle within the nozzle. It is best to run the pipe back to the fuel tank... dont' try to connect it to the fuel supply line. If your engine has a self venting system watch the soldered joints as they've a habit of failing... more engines had the self venting systems discarded as they proved to be less reiiable than the conventional pipe exiting the head, under the rocker cover. Air cooled engines DO NOT bypass more fuel than liiquid engines... this is folklore.. if you're bypassing a substantial amount of fuel, your injectors need to be reworked or replaced. All SR-ST engines use the same fuel return line...
Bill
