I am keeping busy on the Lister 16-2 project. Here is the current status. I am finally getting her back together with fresh pistons, rings bearings, and gaskets. The next area of attention will be the injection pumps, injectors, and the entire fuel system.
I discovered what did this engine in. The locknut that held the #2 cam follower for the injector pump came loose, then fell off. The cam follower was free to rotate instead of tracking on the cam. The follower was skidding and tore up the roller and cam.
With the #2 injection pump not working the engine had very low power. It was traded in on something else at least 25 years ago and had been sitting ever since.
That is all repaired now with a fresh cam, new roller and pin, and is as good as new.
