My car started leaking coolant out of the front of the engine some where, so I went to the parts store and looked at the various stop leaks. Bars has several from cheap to expensive. I chose one in between. It was a complicated application. It was not compatable with anti freeze so I had to drain and flush the system. Then mix the solution in a gallon of water and dump in the radiator, fill, then run the car to operating temp with the heater on, let cool, repeat, etc. Took most of the day to complete the process. A week later coolant is running out of the front of the engine again. I got some Aluma Seal, dumped it in the resevoir when cold, no leaks for a week then it was back. I'm going to get about 5 more tubes of Aluma Seal and dump them all in. If that doesn't work then I'll pull the head and try and see where the leak is. I just hate to spend all that money on fuel driving my truck while my car is out of service. My experience with the stop leaks is that the $1.99 one worked as long as the $10.00 one and was much more simple to apply.
