Quinn,
You are right, technology (the word hadn't been properly invented then?) had moved on and engines were now spinning at three times the lister CS. Less metal, more power, cheaper. New startomatic installations in the UK would have been much rarer by then as most places were on mains power by then.
Glow plugs were used on diesels in the 50s, so along with electric start things were easier to get going when very cold. I remember the Landrover diesel engine (being a conversion of the petrol engine) being an early (for me) experience of dodgy heater plug starting systems. If it wasn't glow plugs it was the 'ki' start like the Fergusons or the manifold heaters on Ford tractors. Even ether, as a starting aid, was around in the late 50s. I remember. The top rings on our Landie were all shattered at 54 thousand miles, most likely due to starting it on ether and heater plugs!
Regards, RAB
Regards, RAB
