Author Topic: Brass oil bolt on camshaft  (Read 2405 times)
greasemonkey
« on: March 23, 2008, 06:25:39 AM »
Hi Guy's I was cleaning my CS3.5 and noticed an oil cap/bolt @ 10.00 o'clock from the value lifter on top of the camshaft it was covered in thick paint and hadn't noticed it before can someone recommend an oil to use and how much, camsharft
oliver90owner
Re: Brass oil bolt on camshaft
« Reply #1 on: March 23, 2008, 07:13:23 AM »
The cam is normally oiled by the running engine.  That oil orifice is only for use to oil the non-drive end after the engine has not been run for some time.  I think Lister suggested about a 1/4 pint run in there.  It will join the sump oil so normal engine oil would be used.
Regards, RAB
