Here are some "roid" #'s to keep things interesting. IMO most of the "Listeroid Jumper" problems were due to poorly cast flywheels not piston and rod weights. 100 grams here or there on the rod and piston are nothing compared to 1.5#'s in the wrong place on a flywheel. The PS kits have much nicer flywheels! Lots of brain mass has been lost on this subject
My VIDHATA
Small end of Rod 1216 grams = 2.680#
Piston assembly 4025 grams = 8.873#
Big end of Rod 2742 grams = 6.045#
Total 7983 grams = 17.599#
Bobweight @ 65% 6149 grams = 13.556#
My POWER SOLUTIONS Kit
Small end of Rod 1147 grams= 2.529#
Piston assembly 4024 grams= 8.871#
Big end of Rod 2584 grams= 5.697#
Total 7755 grams= 17.096#
Bobweight @ 65% 5945 grams= 13.106#
Quinns
Small end of Rod 1194 grams= 2.632#
Piston assembly 3840 grams= 8.465#
Big end of Rod 2819 grams= 6.214#
Total 7853 grams= 17.312# I think I added it up 5 times same answer??!!
Bobweight @ 65% 6091 grams= 13.428#
avg assembly wt. 7864 grams= 17.335#
avg bobweight@65% 6062 grams=13.363#
While Peter's away at the cricket,(sad, sad person ) I've dug up the figures for my 1940 rods:
b/e 2067
l/e 1167
Total rod weight 3234g
From memory, the 2 rods were pretty close to identical.These figures would be for the lighter one, the other being ground to match.
I'll bet Peter's figures come up pretty close. Mr lister seems to have liked to keep things consistent
I might actually get to run this engine again soon.It's taken well over a year to get around to finishing it.hope it's worth the wait!
Brian
It appears Listers have a lighter rod on the big end...that helps.....anybody weighing Lister pistons?
Dave
