Author Topic: Looking for the "engine to alternator" pulley size calculator  (Read 7202 times)
sb118
  • Biofuel Bandit
I know it's here somewhere but i can't find it!
cheers.
First love - 1975 Lister SR1, gone to a better place (running a saw bench actually ;))
True love - unknown vintage CS6/1 with SOM flywheels
linkie to the project so far --- http://jestersltd.com/pics/index.php
Lister owners do it at 650 strokes a minute ;)
Halfnuts
Re: Looking for the "engine to alternator" pulley size calculator
« Reply #1 on: March 06, 2006, 08:17:36 PM »
What for you need a calculator?  The ratio of the diameter of the two pulleys will be the same ratio as the rpm ratios.
Diameter 1 * RPM1 = Diameter 2 * RPM2
Example:
You have a 24" flywheel turning 650 RPM and you need 1800 RPM at the generator.  What size pulley do you need on the genny?
Diameter 2 = (Diameter 1 * RPM1)/RPM2
Diameter 2 = (24" * 650 RPM)/1800 RPM
Diameter 2 = 8.67" pulley will give you 1800 RPM at the generator.
jimmer
« Last Edit: March 06, 2006, 09:02:05 PM by jimmer »
