Could it be low compression not allowing the fuel to ignite ? Could it be something amiss in the injector pump ? Maybe a stuck output valve (forgot the technical termĀ - the thing that you encounter when you take the fuel line off the to of the IP).
Just some thoughts ....
If it was me, I have a spare IP and I would install that and see what happens.
Jens
I was not aware that there was an output valve in an injector pump, I don't know anything about them. The only injector problems I have had on any other diesels was smoke and that was the injector itself.
I been thinking about getting a spair injector pump and injector, Maybe it's time to quit stalling and do it.
I think the compression is ok because when it is not missing it runs perfect. Also when I try to start it by hand, it is still a bear. I can barely turn it over by hand with the flywheel. I have to wait and let the compression bleed off and move it a little farther several times to get it past TDC.
