Author Topic: Changfa rebore and crank regrind  (Read 5195 times)
emerald
« on: January 08, 2008, 11:57:55 AM »
Does anyone know if the Changfa engines can be rebored and the crank reground, or is it a case of replace the cylinder liner and crank when they become worn?
rcavictim
Re: Changfa rebore and crank regrind
« Reply #1 on: February 08, 2008, 09:26:10 PM »
The cylinder has a wet liner so it is meant to be easily replaced.  I would not hesitate to freshen the bore after the first set of rings need replacing with a deglazing stone set on a power drill without removing the cylinder sleeve.  If you overbore then you need to find an oversized piston and likelwise oversized ring set.  That would likely cost more than just a new liner.  Given the cost of machine shop labor in North America it may be cheaper to purchase a new crankshaft.  That way stock lower rod bearings will work.
Which Changfa do you have?  How many hours on it that you`ve worn it out?
-Changfa 1115
-Want Lister 6/1
emerald
« Reply #2 on: February 09, 2008, 12:14:39 AM »
After talking to some people in Thailand they tell me nobdy there has even heard of the ability to rebore the liner and regrind the crank. Those parts are not listed anywhere and means the parts are disposable even in countries where labour costs are reasonable.
I posted this for a guy who owns three Changfa's in South Africa and asked if I knew anyone dealing in parts. I think the guy has gone to the factory now after his email to two US parts people went unanswered. He has an 195, 1115 and a 10HP air cooled, not sure of its model no. Its the higher speed engine and gets very hot in their climate, probably too hot. He tells me the 195 and 1115 have about 8500 hours on them and the air cooled unknown. He did run a little low on oil a few times, but not run dry. I guess that didnt help their life span. The bearings all still feel good according to the guy, could be Japanese I guess.
It seems a guy could expect 10,000 hours on these engines based on what this guy has seen and they are his only source of power. He uses big tractor radiators and water pumps on the engines. He also replaced the silencer (can we call it that?) with the rear silencer from a 2.5 Litre diesel 4x4.
A few of his neighbours run these Changfa's too and no problems reported.
I run 4 Lister CS's, all genuine Lister engines. I worked on a lot of oid's and some Changfa's. The Changfa's are a far better engineered engine and the QC is very good. No bad castings have been seen to date. They look like they will have a better life span over the Oid's without the drama of having to machine parts when you buy one. The cheap bits that I dont like on them are the silencer, fuel tank and cooling tank. The fuel pipes are best replaced too.
I will buy a few Changfa's this year to try out here long term. One will drive a genset for my workshop and I will put another in the back of my Landrover for portable use.
emerald
« Reply #3 on: February 14, 2008, 03:33:33 PM »
Was contacted by one manufacturer of a Changfa type engine (Not by Changfa themselves)
There is no over over size piston and rings produced and no undersize crankshaft bearings produced either.
So they you have it, from the horses neighbors mouth so to speak.
Emerald
