Zeke:
good to hear you got it up and running
some observations if i may, and a few suggestions
1. the yx180 is rated at 8 hp, i suppose this is a continous rating?
so 8 hp at ~750watt/hp = 6 kwatt output
2. no alternator (automotive) is going to be much over 50% efficient, especially figureing in drive losses
which in your case are significant,, so lets just figure 50%
3. so we got maybe 3 kwatt electrical if all is perfect
4. 3 kwatt at a charging rate of ~13.8 or so is about 220amps or so, but
5. your alternator is not going to run for long at this level before the balmar senses the overheat and defaults to half power
so now you will be charging at maybe 110amps max,, again in a perfect world
so:
i would suggest going into the programming of the balmar, and reset the output or reduce the output to no more than 125amps at
bulk/absorption voltage,, this might be somewhere around 60% capacity setting.
then i would run it at this level and see if the temp rise on the alternator stays below the default temp sense setting of the balmar
if it does then maybe reprogram and set it up another 10amps or so, and retest,
if it does not, you will have little choice but to reprogram and reduce the alternator output
if you persist in trying to get the 280amps output on anything like a continous basis it will go up in flames if it weren't for the balmar
and its ability to protect you from yourself.
i know you want to believe in this specially prepared ford alternator, but i have to tell you it is not reality to expect anywhere near 280amps
as configured,, it just is not going to happen save for a very short duty cycle,, maybe 5%
there are precious few alternators that can deliver anything like 250amps continous for deep cycle battery charging and they all cost a couple grand.
i write this so that you might protect your investment and get good use out of it, i would hate to hear that the alternator went up in smoke
or the balmar was damaged in an effort to get an output that is unreasonable for what it will do.
you need to think of this engine/charger as a tractor not a dragster.
respectfully
