Doesn't exactly work out that way.
What we refer too as 240 AC is actualy the RMS value of the AC wave or the DC equivelent for doing current and load calculations.
http://en.wikipedia.org/wiki/Root_mean_squareSo lets say you full wave rectify the the RMS voltage 240 vac what you actuly get ont he other side is the rectified Peak value and thats closer to 340 VDC if my memory serves....
Things can get realy wierd now if you take a multy meter and read that pulsing 340 vdc because the average meter will read the average voltage and depending on the riple that can be much lower ( if you want to take a guess at how low it can be multiply that 340 by .9 to get the average I think ). Now if its a three phase source and or a capacitor to filter you will have less riple and the average voltage will be higher.
Speaking of higher, I'm having flash backs to 1 year electrical at NOITT learning and puzling over all this shite. Oh college daze
Also good reading and much better math and explainations than me...
http://en.wikipedia.org/wiki/VoltageIf you own a volt meter like this
http://en.wikipedia.org/wiki/Image:Digital_Multimeter_Aka.jpgFlll those two sockets with silicon to the left of the leads....
Someday if you get into the habbit of using them you will forget and change the range on your meter to do a voltage check and poof! You may also get burned or shocked, much better to buy a proper clip on amp meter....
