From an economic point of view, running a Listeroid simply to sell power makes no sense. If fuel were free, the cost of the genset, it's lifespan, it's maintenance and overhaul costs and the free labor involved exceed the KWH cost of most utility companies. I expect a listeroid to achieve 5000 hours before overhaul, run on very clean fuel. It could be more, but it is likely that full overhaul at 5K would prevent problems down the road. 40,000 hours is a pipe dream. Also a proper overhaul at 5K would mean another 5K of nearly troublefree service.
With fuel at 1 dollar per gallon, just the fuel cost would far exceed the KWH cost of most utility companies.
Now, remember that free fuel is not truly free, just in case you were thinking biodiesel or SVO. You must transport it, filter it, Store it, deal with it and the problems it causes.
I see the Listeroid as a simple, reliable backup power supply. Or a remote power supply. In both situations, the cost of power is not as critical.
Right now, my Listeroid burns enough fuel dollars to cost about 5 times the Florida Power and Light rate. And my genset cost me a total of many thousands.
Chris
