People get confused because of tuned exhaust on 2 strokes where you actualy have back presure and it provides a power boost.
...if the backpressure is at just the right time.
On a piston-ported 2 stroke, the reflection wave from the exhaust system, if tuned just right, can provide some supercharge. Basically, the system works like:
1) inhale mixture through carb into crankcase (extra points if there's no reed valve - enigne is fully piston-ported).
2) blow mixture through transfer ports scavenging remaining exhaust gases out the exhaust ports. If your volumetrics in the intake cycle work out well, you can blow a little more mixture out the exhaust port than the cylinder will nominally hold.
3) piston starts to come up, closes transfer ports
4) reflected pressure wave crams the excess mixture and a little exhaust gas back into the cylinder
5) the piston closes the exhaust port.
it makes for an incredibly peaky engine, but it can make for better power, better fuel economy, and increased knock resistance (because of the EGR).
