Alternative fuels > Straight Vegetable Oil
Nextera canola oil
rcavictim:
Here is the DIY injector heater for my JD175A. The spacing between the two injector hold down studs on the head was just a bit too narrow to clear my fragile ceramic beads and many got broken during the installation. It still works fine however. The wire is about #14 gauge diameter and is salvaged from a high power motor start resistor. Due to the heat it is imperative to terminate the ends in a solderless, bolted connection.
[*] Previous page
