Ok , so here's my dilemma, I've not purchased my genset yet, but I want the 650 RPM. Only need about 3 or 4 KW (6 HP) All the stuff about balance, and how poorly balanced engines & flywheels have been, with either sand or curry internal and external. I'd thought of the 10/1 route, with heavier flywheels (internally balanced engine ?) and throttled back to 650 RPM is this an inherently better balance, or is the chance of it being out of wack, just as great ? It appears my retirement location will not have reliable sun in winter, and I'll likely have to run the generator daily, to top off the batteries. This will be a lot more runtime and wear on the mount and anchor concrete, and I'm thinking the better the beginning balance, the better off the long term will be.
I like the idea of grouting mild J bolts into cast sockets in the slab, I'm concerned that directly into the concrete will loosen/fracture, and hope the grout will be stronger.
open to other bomb proofing suggestions. I'm also planning on a section of chain link fence inside the gen shed, in case the flywheel comes apart somehow, it should slow the larger chunks somewhat.
