jens---
My future book is about how EVERYTHING is the same, except for time and scale.
Everything that flexes DOES break, it's just a matter of how long. Every flexible part in that car has a finite life until failure. Some can be mitigated by re-heattreat or additional chemicals to prolong that inevitibility.....but it's GOING to fail.
So-far today there have been five reported earthquakes of 5.0 magnitude or larger. Consider those over-ride, subduction, slip and compression fault failures as weld cracks.
It all boils down to a question of mass and how Newtonian forces act on that mass. I'm sure my MT-II 6-1/5ST running out there now has vibrations to it, but I can't see it in a glass of water sitting on the valve cover or feel it through my bare feet.
The OLD one, MT-I, made my desk lamp jiggle 180 feet away in a different building and snakes dropped close to it had a nervous fit until they'd gotten more than about 15 feet from it. It was bolted to a 6x6 frame (visible in the photo essay referenced at utterpower.com) that was in turn bolted to a 6 inch on-grade, 'L' shaped slab. It broke of the leg of the L but ran for another 5000 hours jiggling the building up and down about .025 inch.
