AH HA!! THanks Peter--
als-- Put the engine together and RUN it. THat's just a carrier-locator that keeps the cam shaft from bowing TOO much.
Not quite, the fit of the shaft in the bush is quite close, so I'd guess that it is supposed to be a 'proper' bearing.
Mine is a 1944 engine and has little wear/slop in it, although it is a Lister, not a clone.
I'll take a picture tonight and put it on our website.
I'll also look at the Changed Number listing and see if any modifications were made to the bearing.
Peter
