Yes
And thanks for the reply,.
This Power Solutions 12/2 has a modified bolt whereas the last 1 1/4 inch has been turned undersize (apparently with a stone arrowhead) past the thread roots, creating a device; bottom half being a straight pin and the top half being left as a bolt. It is rope sealed under the bolt head, to the deck. The pin protrudes down into a corresponding hole in the cam bushing. When snugged down to effect the rope seal , it prevents the bushing from spinning in the block, but does not bottom out. I assume a bottom out would be the cam but need to check that. It is a LOOSE fit staking pin contraption. It does work, probably just fine, but it just seems a bit loosey/sloppy to me. And the original Lister sectional drawing describes it as TAPER PIN size 6.
Is yours similar?
I either,
a: don't understand the brilliance of this simple effective time tested tough flintstonian design.
b: might be able to fix this by cheating. Smear the bushing outer with whatever space age polymer has the best pitch on the package at the auto parts store. As long as the stuff is not some kind of amazing insulator, it seems like good idea to me. But that could be me. I know people who swear by this kind of stuff. I also know others who swear at it.
Any other PS 12/2's out there on final?
Issues I've been dealing with:
New oil pump check valves.
Sump cartridge immersion heater.
pressure lubing rear cam bushing, and ?? else
head porting (really just radiussing the backside of the intake valve seat)
drilled dippers (ths was easy to do and seems almost too obvious)
Lexan sump cover
thermosiphon cooling w/ 3 way diverting valve.
liner protrusion
tappet face regrinding (CHEAP! toolpost grinder that worked GREAT!.)
etc etc
Many questions.
A few answers, but learning, and having a blast
I've been read only for awhile. Thanks to ALL of you for the wealth of info already, AND the entertainment. Some of you should be writing professionally. Maybe you are.
Thanks again
