It wasn't so much a flat top as another frequency ringing across the peak of the sine wave. I have to look back thru my pics, but I may have been at a higher than normal output voltage at that point and not reducing the excitation as much as I could to compensate for the increase the caps gave me. I don't have a large variety of resistors of that capacity to combine so I was taking what was adequate to accomplish my testing. Excitation might also explained why it wasn't consistent from cycle to cycle which would go along with excitation induced, if a particular harmonic winding was outputting a little greater when stroked by the rotating magnetic field. It could also be that one diode set flows a little better than the other.
Ron
