Do you actually have to beat the keys in that hard?
Not if the shaft, hole, keyways, and key are properly sized.
I made an arbor a while back for grinding some parts. The end of the arbor fit in a hole in the part. The arbor was split in one place and had a tapered hole in the center with a matching tapered pin. Hole in the part was about 0.0003" larger then the arbor.
One light tap on the pin from a 6 oz. hammer and you may as well have welded the part onto the arbor.
