Christian (Holter), you are correct, the technician(s) did not recommend the Windy Boy.
As has been mentioned previously, product liability must be drummed into the tech support guys and the summaried answer they must give when someone like me asks the questions is ..."SMA make inverters for PV and wind turbines, we do not have an inverter for what you are doing"
Now, I hope I do not sound like I am advertisng SMA products here but I chose the Sunny Mini Central 6000A because it is very versatile. SMA do not really advertise the fact, but, if you have the installer password (and a piggy back connector), you can configure it for the following "modes" - PV (MPPT), Turbine (MPPT), Constant voltage, Constant current, Off grid.
In my limited experimentation so far, I have found that the PV (MPPT) mode extracts more power than I have managed to do with either the Turbine mode or Constant voltage - but, hey, there is a lot still to play with.
Is there anyone else out there rectifying single phase AC and using the rippled DC as the input to a grid tie inverter and if so, what are your observations and thoughts please ?
Is there anyone else out there using an SMA inverter in a similar way ?
Regards,
Ian
