Great, more good ideas, many thanks.
I do not have a clue how to measure the impedance - is it easy to do ? What can it tell ? What can I do to adjust it ?
The output current from both machines is 17 amps (at about 263 volts ACrms and about 60 Hz).
I have measured the static resistance of these generators whilst I previously had them apart...
Rotor (field) coil approx 17.1 ohms
Stator coil < 1 ohm
Harmonic winding <5 ohms
Amazingly, both generators had exactly the same winding resistances within the repeatability of measurement with my digital multimeter.
Both generators have the same diameter cast aluminium alloy fans with the same number of fins. The castings are poor quality with a lot of roughness to the fins. It is possible that one fan is better at shifting air than the other. Any ideas on how to measure this ? Both the fans "feel" to be shifting around the same amount of air. The slip-ring end screen and the fan-end finger screens are identical in free air flow area. The generator that runs hotter has slightly less opening area into the doghouse and the doghouse sits closer to the generator body - which gives less free open air path than the cooler runninmg generator (which has a larger doghouse which also sits about an inch higher over the generator).
The eddy current view is interesting. I thought that the individual laminations of the stator and the rotor were pre-lacquered before assembly and then the whole thing dip lacquered again once assembled. If there has not been an obvious fault, is it likely that this lacquer system might have broken down ?
Would there be any benefit in me applying a spray acrylic lacquer to the rotor and stator coils and laminations in a bid to "shore-up" the existing lacquer system or would this be counterproductive ?
Regards,
Ian
