Author Topic: Auto or Manual transfer switches  (Read 40656 times)
pigseye
Re: Auto or Manual transfer switches
« Reply #90 on: July 17, 2006, 10:26:13 AM »
You're right Fuelishnot, WWII Props uses a 7.5hp Baldor.
What do people think of this motor?
10 hp 1740rpm 215T Frame TEFC (Farm Duty) 230 Volts Leeson Electric Motor # 140706
    * 230 volts 40.0 amps 60hz.
    * TEFC - Totally Enclosed Fan Cooled - Electrically Reversible
    * Manual Overload Protection - Service Factor 1.0
    * NEMA 215T Frame - Flat Rigid base mount - 1 3/8" Diameter shaft x 3 3/8"
    * Class F Insulated - Ball Bearings w/low temp grease
http://www.amazon.com/gp/product/B0009WSRYA/ref=nosim/104-1221003-4000758?n=228013
I'd use this with a 12hp Listeroid.
Or since I'm net metering, is a 10 hp induction generator a little overkill.  One thought I had was I wouldn't have to run the engine as long every month.  The downside is a 12 hp is double the price of a 6hp.
The nice thing about a 12 hp motor is if the grid does go down I could have a back up 7.5 kW generator.  I know the gen head is a little oversized for this motor but I'm hoping I'd have a little more head room with the 7.5kw for the well pump.
All insight or comments are appreciated.
Thanks,
Steve
randyracing
« Reply #91 on: July 27, 2006, 09:45:26 AM »
pigseye can you sumerize what is all needed to operate unit for net metering in wisconsin,
pigseye
« Reply #92 on: July 27, 2006, 04:10:46 PM »
Sure I'll try to get to it this weekend.  For now, please review this thread from start to finish.  You'll learn alot.
Steve
