Ok, I think the things I said have been not clear enough, I will try again with some new vocabulary an an example:
1. I have no Idea of the necessary torque and rpm of a ship's propeller. I assume, the propeller will be designed for around 2-3 kW at 600-650rpm, you talked about direct drive.
Now we take a standard Lister(oid) 6/1, 6hp@650rpm.
directly to the shaft of the motor can be connected a synchronous generator, either a special permanent magnet (How to proceed with this will depend on the generator itself and should be discussed with the possible generator).
or one with rotor windings and AVR. Perhaps a ST Generator for three phases with around 8 kW and 4 poles (1500 or 1800 RPM). Three cables will go now to a (sealed) box, that has to be made by a friendly electrician. This Box is connected to another switch where you control the boat with 5 or 7 positions (2-3x forwards, 2-3x backwards and one for stop). How many positions will depend on the asynchronous motor.
This Motor could be a multi-speed Motor where you can switch between 4, 6 or 8 poles and a maximum power of around 7-10kW.
If the AVR works at low rpm, this system should work quite well. In full speed the propeller should have something between 600 and 650 rpm, at "half speed" around 400-430 and at "low speed" 300-320. This of course in both directions.
The sealed box is a setup with a number of electromagnetic switches and a complex cable system. I would recommend to use 24V DC switches and one a little overdimensioned 3-phase transformator with rectifier. This 24V DC kan also be used on the Boat for Lamps or so.
The complete system (perhaps except the AVR on the ST gen head) is built with technology not younger than a Lister.
Physics:
The Generator will be driven with around 650 rpm. The voltage of a synchonous motor is regulated with the excitation of the rotor field, which is independent from the rpm and controlled by the avr. If the Generator is brushless, there could be a problem. The current of the Generator depends on the angle between the magnetic field of the stator and the rotor, thus is also independant from the rpm. The generator needs to be bigger for two reasons: The torque, that is needed to drive the generator to get ca. 3kW is bigger than at the rated speed of 1500 or 1880 rpm, because the Power is the product of torque and rpm. Added to this is the irregular speed of a one cylinder motor, which puts additional stress to the generator shaft. If the Shaft of a smaller generator is sufficient for this, even a 3-5kW gen head could be ok. The generator could be also much bigger, but then efficiency will drop, weight and costs will rise and you will have to cranc this when you start. On the other Hand, if these were major concerns for you, you would not even consider a Lister
After that you will have threephase Power of around 400V (US=230?) and 21 Hz(!) With this you can start the asynchronous Motor in the lowest "gear". The maximum Power of this Motor with 6 poles is around 2kW, so starting it with the Lister is no Problem and also the Load from the Water resistance will be much lower, because the rpm will be at ca. 300-320. Now you can switch between the different positions. If you switch between full speed forwards and backwards with no Time Delay too fast, either some protective fuses (that the electrician installs) will blow or the Lister will stop. The same Thing happens when the propeller gets caught or so. Which case of both happens will depend on the dimensioning of the Fuses: If they are only there to protect Motor and Generator (that both can do much more torque than the Lister), than the Motor will stop. If the fuses are smaller and awitch already at the designed Load of the Lister (around 3kW), then you will just have to switch them on.
Possible Problems, that have to be considered in this Setup:
- I do not know, if a differential works at 21Hz, also the Transformator will have less Power, because of the
- The coupling of two Shafts has to be carefully done
- The Motor is not easy to find (used). Perhaps a Motor with two speeds will be sufficient
- The AVR and the rotor winding of the generator will be more demanded, because to keep the tension high at low rpm the magnetic field needs to be stronger.
These Problems could be avoided, if you use a belt drive for the generator, but then the propeller also needs to be designed for higler rpm (~1500)
The Problem of Efficiency cannotg be solved so easy: The total efficiency of this drive system is the product of the efficincies of (Belt drive), Generator, (electric system) and Motor. I suppose this will be at around 60-75% Compared to a Direct Drive that means the same loss regarding available Power and also fuel consumption.
Nevertheless I think a System of this Type could be very comfortable, maintenance-free (except the motor of course), more quiet and (if the electric Setup is well done) very durable.
Christian
