not all automotive alternators are created equal, rather some are better suited for the task at hand
i would not recommend most of the car alternators even though some are high output, usually they taper back very quickly
and when they get hot they drop off very fast and die early.
on the other hand the hd truck alternators are built a good bit tougher, but even in that group all are not equal, some are less desirable than others
i like the high output, low rpm units such as the leece neville 175 amp units and of course the largerĀ units up to 320amps
i also like the prestolite loadhandler series 160amps units, which are large case units and produce good power at low rpms
however,, none of the automotive regulators are suited to charging a battery bank, unless you are running the engine 24/7
replaceing the automotive regulator with a controller from balmar, xantrex, or amplepower will allow for much better control, temp sensing
temp compensation, custom programming for soft start to reduce engine shock loading (saves belts) and give true 3 stage regimes that are customizable for
a specific application.
i like the balmar, but for the money the xantrex controller can be had for about a C note on ebay and is a good value.
efficiency will be about mid 50's % range, so this is why i like the 50/80 regime, kick the batteries hard and get it done as quickly as possible.
also don't wrinkle up your nose too quickly re the mid 50 efficiency, and think that because some inverter/charger manufacture claims 90% plus
some of these claims are about as solid as gas line magnets!
for about the price of a mx60 controller you can get a new prestolite 160amp alternator and a xantrex controller from ebay and also new.
and still have enough money to go to mcdonalds
and i don't like combo units, an inverter should be just that an inverter,, not a charger too
a charger should be a charger and not an inverter
jack of all trades and master of none is what you end up with.
if one side fails, it can make the other side useless as well
i like seperate and redundant components, that are user repairable or servicable
a hd alternator is user servicable or locally servicable for most folks,
and at a hundred bucks a xantrex controller is cheap enough to have a spare.
not many inverter chargers can deliver 140amps continuous if at all
and lastly
the inverter charger will have to take in power from either the grid to allow charging or from a generator
presumably this will be an st genhead
if we assume the st head to be 85 % efficient
and the inverter/charger to be 85% efficient
the net efficiency is at best only 72 or so efficient
then factor in the additional run time to get the same amount of amp/hrs input
and you will be within a sight of the mid 50's anyway.
just my .02
