If you have a great beefy charger, fine.
Just 2 problems,
1) the batteries will take a good stiff charge till they are about 75% capacity, then charge tapers off, then it's time to get the washer machine going, etc.....
2) losses in the battery charging sequence, you loose about 20% recharging a flooded cell battery, AGM is less loss.
Go for a 48V system, less copper loss in the wires, because you aren't pulling as many amps, for the same wattage.
