Alternative use for a Lister CS 5/1
hotater:
Womble--
Thanks very much for the explainations.
Please re-think your throttle/governor analysis.
I believe you have a "Throttle" and not a "Governor". The foot pedal should have a return spring that closes the rack to 'idle' speed and probably some type of over-rev stop made from the governor weights so it can't go over a certain speed.
I'd bet with one small but heavy flywheel the RPMs are higher than a standard 5-1....but still less than 1100 or so.
Tom:
Womble,
Perhaps you should set the throttle similar to a go-cart. To do this you would use a standard governor setup but instead of a fixed mounting for the spring use a lever attached to the throttle petal. Hold the petal to the floor and adjust for max speed. Then set a stop on the rack for idle. Move the stop out of the way when closing the fuel pump paul.
womble:
Tom,
Thanks for your suggestion. We had also considered that and its going to take abit of tinkering to get it to work properly.
I'll keep you all posted.
I've a frost crack to fill up first, looks like the guy before me liked to use gasket glue on everything!! Plus some sludge to disperse in the sump.
[*] Previous page
