Author Topic: END PLAY ON LISTER CS 6/1  (Read 6123 times)
BOGHARD
« on: July 30, 2007, 09:57:03 AM »
Hi  I have just got my first cs 6/1 and it has some end play in the crankshaft can any one tell me if it should be there
      and how much. or how do i adjust it
                                                    thank Neil
« Last Edit: July 30, 2007, 10:11:34 AM by BOGHARD »
ronmar
Re: END PLAY ON LISTER CS 6/1
« Reply #1 on: July 30, 2007, 12:40:46 PM »
Since I saw your other question about trying to identify this engine, is it a Lister or Listeroid?  I think all the original Listers have "Dursley England' stamped on them somewhere or cast into the crankcase access hatch.  Does it have sleeve bearings or Tapered Roller Bearings? I am not sure about end play for sleeve bearings on an original lister(not sure what they would use for thrust?).  If it is a Listeroid with Tapered Roller Bearings, you should have .003-.005" of crankshaft endplay.
Ron
PS 6/1 - ST-5.
BOGHARD
« Reply #2 on: July 30, 2007, 03:48:49 PM »
Hello Ron
               Yes it has got  Dursley England on the crankcase access hatch but I do not know wether it has tapered or sleeve bearings I have not stripped it down it seems run ok a part from the end play.
                                                      thank Neil
snail
« Reply #3 on: July 31, 2007, 05:18:06 AM »
Neil,
    Mr Lister says the end float is .005 - .010" . If yours was made in Dursley it has sleeve bearings. The TRB's are an Indian option. Both are adjusted by adding or removing gaskets under the housing. I wouldn't worry too much if  your end float is a bit over spec, it is a Lister after all !  :D ( did I really put that in writing??? ;D ;D )
Ron,
    The sleeves have an enlarged end face that runs against the crank to take thrust (looks a bit like the big end bearing) I don't think they were designed for much end thrust. Anyone ever seen an automotive style clutch on a CS?
Brian
BOGHARD
« Reply #4 on: July 31, 2007, 08:20:28 AM »
Thank you Brian  I will try not to worry.
                                        thank Neil
