I have managed to break the oil control ring when putting the cylinder back on my piston...
ARGHGHHHHHHHHHHHHHHHHHH!
Now, cussing aside, how do I go about replacing the ring? Do I change the entire set, starting with the oil control ring at the bottom (of course), and work upwards, then lower the cylinder, or can I just slip the oil ring down over the other rings on the piston?
The engine is new, only run at the factory, so all rings as new.
Advice more than welcome.
Many thanks,
EM
