Just a follow-up update of my coolant system upgrade. First, I deviated from my original plan. I discarded the idea of using a large water tank. The system is now configured as follows. From the engine, I'm thermosyphoning to a big flat plate heat exchanger. Total coolant capacity in primary loop is about 6 gals, 5gal in engine and heatx, 1 gal in reservior tank. The secondary loop counterflows with primary, and consists of a taco pump, and 3 valve selectable branches. One branch feeds a water- air heatx, which exhausts the heated air into a soon to be work shop, is now a storage area for wvo. On the hottest day so far (93 deg. F ambient, 108 deg. F room temp), load 75% capacity, this loop was able to maintain outlet coolant temp to no higher then 204 deg. F, with secondary loop outflow from heatex at around 175 deg. F. When this loop is not selected I can optionally keep the fan running, to exhaust hot air from the room. As originally planned, the second branch of the secondary loop, feeds a 30+ feet, 3/4" copper tubing coil submerged in my 24 ft round, 54" deep pool. Pool is 14' from the wall of my engine room. Closed cell form insulated PEX, trenched in 2ft, connects the coil to the engine room plumbing. Water temps in this branch so far, have not exceed 140 deg. on a hot day, and primary coolant exits engine temp varies between 192 & 202 deg. F, as t-stat cycles. So far, I have not connected third branch too house hot water baseboard string. Plan on installing overtemp fuel cutoff switch this week, which I feel is absolutely needed due to coolant system configuration.
