I do not know when, but at some point in its life the lister had a catastrophic failure in the crank departent..
If you look at the other pics, the liner was baddly scored, and the bottom of the Listard liner was broken off in both sides where the flalling crank beat on it as the flywheel momentum wore off...
I do not know what was replaced when it was rebuilt.. Not much as the liner was left as is.. I have since had it re sleeved with a steel liner and got some chrome rings..
So, I would think that the crank, piston, rings, at least were changed, maybe the bearings as well, maybe not....
