I've added some more pictures to my putfile.....
The pictures of interest are of the wiring inside the dog house. I'm not realy inpressed with this so its getting scrapped. I have a biger encloser I slavaged from a joystick remote box and some odds and ends. My single biggest flaw with what the Chinese did is no protection for the harmonic winding and field so this will be added both ends fused at probably 4 or 5 amps and run issolated from ground just as the factory intended. Metering will also get an upgrade, some fusing and a selector switch witht he factory meter so I can flip between L1-N, L2-N and L1 and L2. I may add a amp meter and frequency meter if something that pops up....
Also up loaded a small double pole double throw isolation switch I salvaged ( very retro 1960s Square D ) and a fairly modern Fused disconnect. Both are 30 amp 240 rated. For the curious the red painted switch in a previous life served central blasting switch with fire/prime/short as its function....
The Qc guy has it on HIS bench giving that old defeater a tweak.....
http://www.putfile.com/dougwp/images/102508Still waiting on Pat at Altopro to ship the replacement end bell....
Poor bugger is in pickel trying to fill orders while he moves to his new shop for the currious as to why he's running late on orders.
Waiting on some pictures of a burnt ST 12, I suspect the lack of protection in the Harmonic/field wiring lead to failure. More information as it comes in.
