shifty
i guess i will do this in snippets
"All of your ideas were left untried. Apparently you let other assholes convince you it wasn't worth the time. I guess you were never the type to actually try anything anyway, preferring instead to waste the hours away endlessly pondering and discussing, accomplishing nothing other than stroking your own ego."
you really should do a bit more reading! holy crap! apparently youth has no patience? do you really think i let anyone talk me out of anything? really? apparently you did not avail yourself of the concrete vs resilient mount discussion?
i may not have posted all of the work i have done here on this forum, but i have on others, and there is much that i have not published, for reasons you likely would not understand.
ego? really? i gave up on that one years ago! ego? seems like something you are not in short supply of.
"Porting isn't rocket science. You could take an old junk head and practice, and in 3-6 hours work fully port a Lister cylinder head from start to finish. "
simply picking up a die grinder and a set of stones surely is not rocket science, however getting results is not as simple as some would like to believe... quite the contrary!
one must understand what all is involved in proper port design, especially when it comes to a slow speed diesel! simply going in an removing things without understanding why they are there is likely to result in an engine that not only does not make more power, but likely less and more likely run dirtier! some of the designs incorporate a shelf that is designed to provide additional swirl and aid in scavenging spent gasses... leading to a cleaner burn.
now as for all the other drivel bounded by less than appropriate language and offensive behavior... all i can say is this...
grow up dude!
if you truly are as intelligent as you would have others believe, you would not have to resort to ridicule and profane language to get your point across. doing so only proves your lack of depth or lack of understanding of the subject at hand. this is a schoolboys approach to debate, when forced to support his claims to resort to ridicule, foul language and name calling.
