rmchambers: Basicly, this project is to see where the basic listeroid can be taken. Issues such as the emissions as well as reliability are considered.
The reason for EFI on this engine is to investigate optimal timing IP (initial point) and duration for every senario I can conceive.
I can reprogram a fuel chart much easier than I can change timing on a PICO pmp.
If these engines are to survive, let alone flourish, they need to meet the rules in force now, regardless of what comes in the future.
OK. Since you asked, (yes I realize you didn't) the goal is to develope a kit of parts to adress the reliability issues first.
Roller tapets, rocker arms properly hardened pushrod ball ends, etc. Possibly find a way to "produce" the belt drive I use on my 10/1 generator engine,
so anyone could retrofit to an existing 6 to 10/1.
I cannot do anything about the existing quality issues from India, sand, plaster and such, BUT maybe I can do something else to help.
BTW, the six stroke cycle I reffered to holds a lot of promise and is another reason for EFI. I will need the electronics to make that work.
