I live in the midwest USA. Plenty cold in the winter. Rarely sunny enough for solar and rarely windy enough for decent wind power. So that leaves me with a FuKing Listeroid 6-1 in the basement doing the cogeneration thing and happy as a pig in shxx. My setup has about 1,500 hours on it and has been fun to say the least. Once I got it sorted out (sand, rings, con rod bearings) it has been a walk in the park. It does want a little supervision. Today I noticed that it had walked about two inches on its isolated concrete pad. I have six hold down bolts that clamp the web on the bottom of the I-beam. And I HAD a 5/16 bolt that went through the I-beam and into the concrete. A year's worth of vibration finally sheared that off and she went to walkin'.
A new 1/2 inch bolt newly installed this AM should put a stop to that.
l have planned a much bigger cogen setup to heat the entire house with radiant heat.
I cook my own biodiesel for the VW and the Lister and I make premium quality "nectar of the gods" fuel. On the one biodiesel discussion list, I am sort of the quality control nazi.
Used to drive a truck, used to work in the oil field in texas, used to be a natural gas pipe fitter, used to be a photographer/reporter for little weekly newspaper, used to be a tractor mechanic, used to install high end wood stoves, used to run a printing press, took a couple years off and built a superinsulated passively solar heated house in Ontario canada, used to work in a copper wire mill, used to drive a school bus.
Then I "grew up", at least as much as I ever will I think. For my present day job, I'm an eye doctor. I love my day job, which sucks up 50 hours a week and does tend to cut into my alternative energy alter ego life.
Not enough hours in the day.
Finest regards,
troy
