Now we have a separate (although probably related) problem. It started fine for a couple of weeks but now it won't start - it tries but doesn't 'catch' - wheras it used to go 'chug chug chug' faster & faster & would then run, it goes 'chug chug chug' slower & slower & dies. There is black smoke from the exhaust, so it is firing. Does anybody have any ideas please? I've checked the air filter & it is filthy, although I get the same problem with the air filter removed. Is the presence of an air filter that critical? Also there is no fuel filter in the filter bowl. Is this also a critical problem?
One alternative I have been contemplating is ripping the old engine out & putting a small petrol engine in. I'm guessing that I could put, say a 5.5hp Honda engine on the roller & use a V-pulley on the output shaft to drive the rubber belts that turn the transmission input pulley. Does anyone have any experience of doing this? What size (power) engine would I need? Obviously I can adjust the gearing by varying the diameter of the pulley on the engine, or I could connect it direct with a fenner coupling. There's a new engine on eBay, item no 290124504460. I'm wondering whether this sort of thing would be powerful enough.
