It is not that it will not turn the generator head, mostly it is just that then your power is limited by the engine, you will only get 3 to 4 Kw out of it.
OK. So in the end it's just the same thing as running an ST 5KW gen head right?
There are differences but it should work fine.
The reason I 'm hot on this is that Harbor Freight just opened a store near me so, although I'll have to pay sales tax, I don't have to pay shipping. Also, the harbor freight one is $150 (plus freight) cheaper than the ST 5KW head.
So where do you get pulleys for it and what size pulleys do you get if you're running a 6/1? Do you run the equation for the 24" flywheel using 650RPM for the engine and 3500 for the generator pulley?
Always nice to have the chance to look something over good before handing over money, also makes a no name or address cash transaction possible. The fewer people who know what I spend my money on the better I like it.
I had an old used $30 4000 watt 3600 rpm head on a 6/1 for a while, the diodes in it were burned out when I got it and after fixing it with some scrap box parts it run hot even with no load, burned it up running a 10000 BTU AC last summer. Just had one 4L1000 belt running on the flywheel with a 4 5/8 inch (maybe a little bigger 4 7/8) A/B pulley on the head. I did have to slow the engine down to something like 610 or 620 rpm..
Remember when figuring the ratio V belt pulleys are measured on their OD but you are running the belt on its ID on the flywheel.
When calculating pulley sizes all you need to remember is the speed ratio is equal to the diameter ratio and solve for the unknown variable. There are calculators all over the net if you need more.
After burning up the 4Kw head I wanted to get a 208V 3ph head, and I needed it soon because it was hot and I had gotten used to the AC.
Smallest I could find was 25Kw, so ordered it and a 3 grove A/B pulley, 8 7/8 I think, engine is still running a bit slow. With V belts it is more difficult to get an exact speed ratio because the effective diameter changes so much within the width tolerance of the belts. I have been running that big head for a while now with the same single 4L1000 belt, at first it chirped a bit on the power stroke but after it wore thru the paint on the flywheel it stopped doing that unless it is really loaded down to the point the speed is dropping off.
I do not expect the belt to last long and it is not as nice as a flat micro v but it was $11 at the hardware store on the way home from work.
