Ron,
I was expecting a lot worse than I saw from your O-scope traces. The DC ought to be able to get cleaned up with a better bridge rectifier setup, I know there are better ones out there. Before he retired my dad made them, huge honking ones for use in MRI machines which would have not even broke a sweat with the load an ST head would put on it. Too bad he retired before I started on my power generation thing.
There is still a slight blip on the up and down swings even when excited from a steady DC source so there's something else at play here that most likely Doug can pinpoint.
It looked clean enough that most electrical devices wouldn't have an issue with it though. Might be some noise coming through on a stereo or something but when the lights are off, having hum free stereo is the least of your problems.
Thanks for sharing, you know what they say, a picture is worth a thousand words. I'll be interested to see what happens when you increase the capacitance, see if that sands off the edges a bit.
Robert
