Hello: I am new to this forum, but I need some help. I bought a 14-1 Lovson new and decided to tear it completely apart to learn about it and to see what improvements I could make on the design. Before removing the camshaft and crankshaft I did not notice any timing marks. The generic manual shows where the marks should be, but none are visible. If there any marks on the crankshaft gear, they are not visible because of the roller bearing. When removing the cover for the camshaft the camshaft came partially out and I am not sure I put it back in its original position. There must be a way to do this. I can get close visually, but I could be off 2 to 3 teeth. Also has anyone tried adding a oil filter or changing the oil delivery system. Any help would greatly appreciated.
Thx, Jim
