My roller was drilled a little bit off, .018” to be exact. If my measurements are correct my timing changes about 6° for every full rotation of the adjuster and one thread on the adjuster is close to .045” That means my timing varies by up to 2.25° randomly. Depending on where the roller is when timing is set, it could go up, down or a combination of both. It could also explain why I have had some trouble timing it.
It looks like the roller is held in place by a hollow pin and a small tapered pin was driven in on one or both ends to secure it.
Does anyone have experience taking these things apart? I don’t want to bugger the thing up and have to wait for a new one. I have a drill press but no lathe.
Thanks, Geno
