Captain Steven,
I have been slowly working on the TR2, As soon as I pulled the heads it would turn over. Front piston carboned up real bad. Evidence of rain water in thorough exhaust valve, clean out carbon some pitting on top of piston. Pull out valves, exhaust valve and seat pitted. Heads off to machine shop for seat clean up and valve guide replacement, labor $40.00. Went to install new valves and the groove for the keepers to small, back to machine shop cut bigger grooves, $20.00, Machinist lost keeper in chip tray email dieselgman to send replacement. Was getting ready to install the stub shafts that hold the valve rockers, and got looking at the oil holes and noticed three of the stub shafts had not been cross drilled for oil to get to rocker bushings ,too hard now to drill, funny this engine probably has over 5000 hours and it still worked this way, must be lots of splash in the top.
I don't have the luck to not replace them, so 3 are on the way from England.
While the heads were gone after pulling the injectors, front one rusted up and pitted. I had new nozzles but was to chicken to try to take them apart. I hooked up the injectors to the high pressure pipes bleed out the air and spun it over by the starter, rusted one nothing but other had four spray pattern but not even, exchanged front to back and back to front no change. So off to the injector shop $50.00 labor.
I all ready had cylinders and pistons and after seeing rust and pits decided to pull cylinders and pistons, front piston had second ring stuck hard so I guess I did right. On to the connecting rods small bushings need replaced, off to the machine shop, replace bushing and ream to fit piston pin $20.00 labor. Picked up today. South Prairie Larry
