A bearing that stays in the end bell and not on the shaft is a warning sign something is a miss.
The end bells should slide on/off bearings with moderarte effort with little wigle. Of course of there is dirt and rust it may require some penetrating oil.
A bearing should never come off a shaft with out the use of a puller and should always require about 200 F worth of difference in heat to slide on the shaft. If you can slip it on cold all the way with your hands and back offf again its too loose something is wrong! The fit of the outer race to the end bell should be possible cold but require effort ( effort means wigle, some light oil as much force as your able to with a bare hand, this is not a job for a hammer of any kind ). If you preheat and end bell to make the job easier again no more than a 200 F spread in temperature and it should slide on with minimum effort. If its too hard to slide on with heat again something is wrong stop and find out why.
The wigle test:
When the machine is reassembled grab hold of the output shaft. Try and move the rotor back and forth. If your head has a spring washer you should be able to compress it in the housing with a lot of effort and it should come back. It should be obvious the out races of the bearing and end bells are excerting enough presure to make this difficult but not impossible. With the machine sitting on its feet pull the out put shaft up and down there should might an almost undetectable movement caussed by the .003 C3 clearence of the bearings, but this is very hard to feel and you may not.
If you are sure you feel some up and down and the end bells slid on realy easy or the inner race to shaft was a little loose of a combination of both trouble is in the mail. Run the head with the from now on watch listen and from time to time repeat the wigle test untill something changes and it gets worse, you need to have shaft and housing rebuilt. Any changes like increased noise or a slightly warmer than normal bearing, tinny hissing sounds
indicate things are begining to fail.
When ever you strip an generator or motor for service, its good practice to clean its windings with an electrical solvent and repaint it with Glyptal 2001 ( A ). Never use compressed air over 30 PSI to remove dust .
