i understand some of the chevy luv trucks used them, and some of the chevettes
but you may be right on the 1.8 version, but i do know that the automotive ones had rotary pumps
thermoking also used them on gensets used to provide power to electric refer containers, and from what i am told they would
run for friggin ever.
one of the thermoking techs i talked to told me he has seen c201's that were so worn out, that it was beyond belief, and like a bumble bee
they kept right on running.
and yes you can start em on the ground and they just sit there and run like a sewing machine, really smooth running little engines
there were millions of them made and should still be one heck of a lot of them around, overhaul kits are reasonable as well.
the flywheel has 6 rubber bushings so that the drive hub from the compressor having pins, drive in this manner
i have been thinking that if one made a bellhousing to mate the engine to the st head you would have a very good drive
relatively inexpensively
