Doug,
You are not getting the jist of what I said. Please read it again.
It is like the Z winding represents your big toe, and you have just stuck it into a calm pool of water. It causes ripples in the magnetic field by being there. These ripples end up on the output of the alternator, apparently by transformer action. By leaving it completely disconnected, i.e. NOT using it as a source of power for any purpose at all, it is the same as unwinding it from the alternator frame and selling it to the scrap man. It is not there to induce ripples in the magnetic field.
Hi list,
Jumping in a bit late here, with what might simply be a brain fart.
If the above is assessment wrt induced distortion is correct (I've not seen the Z winding inside an ST), but is it possible to replace the single Z winding with a contra wound pair, in that way to possibly achieve cancelations of of induced fields? Haven't really thought this out yet, but one winding could be connected to a second bridge and also power the field.
Or keep the original winding, and add a second z winding 180 deg. opposite and feed the existing bridge (push-pull anyone?)
One local rewinder here add field windings to replace cooked or NLA avrs, mostly old industrial gensets.... I know it works, albeit I dont know how cleanly the output might be..
I am concerned that some report that they cant really power anything with the ST, as I'm currently looking into them for lister-st setup.
regards from Crete,
nikos
