Jim Mc:
Thanks for all your ideas. Please note my responses below.
1. Ditch the Z winding. (that's the so-called harmonic winding, right?) Instead run a power transformer and full wave bridge off the stator output for the exciter source.)
The main advantage I see to using the Z winding is that it saves having include a transformer to power the field. It also avoids having to draw the power for the field from generator output--although we are only talking about 100 W or so. Unfortunately, the Z winding is something of an unknown in that I can't say what DC voltage we will get after we filter and rectify it. We may find that the this voltage is not high enough to serve. If that turns out to be the case, then we would have to get the field power from the generator output as you propose.
2. Plan on running that DC exciter at a fairly high DC voltage. (somewhere around twice the field requirement) Got to, in order to change the fiield current quickly (the field is a big inductor) so that we have a hope of clearing up flicker from our slow-speed drive.
If the filter after the Z winding rectifier does what I expect it to, we will end up with close to what you are proposing here. Whether we really need to be able to change the field current that quickly will depend on the overal stability of the system. (More on that subject below.)
3. KEEP the crowbar. In fact make it more robust by adding a second zener to activate it sourced by the exciter DC supply. That way, a failure in the sense transformer or its rectifier would still end up in a successful crowbar shutdown.
Good point. If we lost voltage feedback, regulator would tend to drive the field to maximum current. It makes sense to modify the crowbar circuit to test for this. By the way, there is also an overcurrent protection function built into the regulator chip. All this requires is a current sensiing resistor in the field circuit. I am inclined to go both ways here.
4. I'd be tempted to run the LM2578A off the sense supply instead of the exciter supply (fewer parts). (maybe...)
This would depend on how much output the generator makes from residual magnetism alone. The complication in the existing low voltage power supply is designed to allow it to produce a regulated low voltage over a wide input range. My thinking was that the Z winding voltage would be higher than the output of the step transformer under startup conditions and that we could use that to get the low voltage power supply up and running before we are putting any current through the field.
5. How about driving the field on the low side - N channel MOSFET? (fewer parts)
The regulator chip shown is not really suited for driving a MOSFET or an IGBT for that matter. It is capable of either sourcing or sinking current, but not both. I am looking for a regulator with a totem pole output. Once we have that, we could go either with a MOSFET or an IGBT.
6. Of course be super careful with the grounds so the high field current doesn't affect the sense side of the regulator.
This would a major concern for any circuit board layout whether it be a printed circuit board or a hand wired board. In fact, this is something that may make building a hand wired board difficult for someone who didn't have the experience and knowledge to know how to keep this signals properly isolated from eachother.
7. I've no idea how well this will self excite. Might want to add provisions for a D cell and momentery 'flash' switch.
This is a big concern for me, too. I am hoping the low voltage power supply design will make flashing the rotor unneccesary.
8. That filter cap on the sense supply shouldn't be very big for fast response to voltage fluctuations.
As I remarked above, stability is big concern as well as a big unknown. As with any other type of circuit involving feedback, there you always end balancing response time against stability. My thinking is that we start with very sluggish response and then do some testing to discover how fast we can safely make it. It may be a good idea to include an adjustment for this so that peole have the freedom to set the response time where they want it.
9. Don't see why we need a zener across the field - regular fast rectifier should be fine (cheaper)
This was a brain fart on my part. It is actually supposed to be a Shottky diode. If the switching frequency ends up in the low kHz range, as I am hoping it will, then a standard rectifier diode should be fine here.
Best regards,
Andy Hall
