I have been reading George's cd, and now have some of the easy to remove parts off my CS.
I have a chunk missing from the bottom of my cylinder sleeve. It is almost big enough that I can just see the edge of a ring at bottom dead centre. Anyone think this is a problem to worry about?? It is a listard cylinder. The chunk is not in the case, so I assume it has been missing for quite some time..
I would like to fully take this engine apart, I was going to order the gasket set from gasket to go, anyone have any better, or closer to canada options??
I have a furnace oil filter unit currently installed, Would an automotive type unit be better, I was considering a heated unit such as the one found on dodge diesel pickups, if the furnace filter is sufficient i will just get a new cartridge???
The compression changeover started to leak when fully open or closed. When I took it apart there was a small piece of copper disc sitting in the cup. I could not find this and think it was put in place to put off proper resurfacing of the valve faces. Does anyone know if there should be anything copper in there, or just properly mated surfaces??
I also have a rad leak, I am looking for a rad shoppe to rebuild the core..
I have posted pictures of the cs before it was shipped to me on coppermine. And hopefully will get some good pics tomorrow of the broken bits.
Anyone in Canada that has spare parts for sale??
Thanks,
